is this real or just bs?
Re: is this real or just bs?
seems like a much easier route to just plug in a blue speedo converter to deristrict the bike :) i still havnt fitted my mph clock face ricky done me but tbh, iv got a blue converter too, be easier to just plug that in lol
- Yakama
Cheers I did see that unit though it looks just like an HRC unit with a bluefox sticker over the top of itNeosophist wrote: Interestingly though i've found a blue-fox box that is the same as the SP unit but made by Blue Fox... maybe Liam would be interested in it:)
Surely this cant be the case as the NC29 & NC35 ran in the same class and both of these have HRC CDI's in their HRC manuals.CMSMJ1 wrote:My tuppenceon these SS boxes is that they are a tool for the regs at the time. SS/SP - road related class - so I would assume you were limited in running the std CDI. So if you then removed the speedo you needed something to stop the bike limping.
That is it...as simple as that.
I recall other people doing some testing a few years back and nothing was found ot be different. The Placebo effect asaide, I 'll be no-one could tell either way whether an SS box was fitted or not.
Also I read somewhere last night that someone thought that the SP unit was to stop retarding at high rev's in top gears??
It could indeed stop the retarding at High RPM / top gear.. some kind of manual / over-ride.. hence the spec's saying high-octane.
But again, without all the rest of the gubbins you wouldn't benefit from it.
It isn't a HRC SP unit with sticks I don't think
Wires are different colours for a start.. plus the sticker isn't raised where the HRC writing would be
is the blue fox one plastic? as the HRC one is cast alloyNeosophist wrote:It could indeed stop the retarding at High RPM / top gear.. some kind of manual / over-ride.. hence the spec's saying high-octane.
- Yakama
The HRC is plastic too and Neo I think the later HRC ones didnt have the raised HRC bit like the earlier ones i.e looked like this:
These ones have different colour wires from the earlier ones. I think its one of these ones with a Bluefox sticker on it
Interesting.
Is that a genuine HRC box? It's odd for a Honda unit not to have Honda written on it (unless it's on the back?) Every SP unit i've ever seen has raised decals. (different part numbers? I don't have the HRC manual here to check)
And the wires are still different colors between all 3 boxes! (Not that it means a lot)
Probably all do the same thing anyway.
- Yakama
It doesn't say Honda or hrc anywhere but does have the hrc parts designation NKA stamped on the back
The HRC one i had was cast alloy! it was pretty heavy,
someone i knew also had one on theres that had road rash from a previous crash and exposed a lot of deep gouges in the alloy.
- Smev
- Bike owned: NC30 of course
Did it expose anything else? like a load of potting (rubber) and a small resistor?!!!porndoguk wrote: someone i knew also had one on theres that had road rash from a previous crash and exposed a lot of deep gouges in the alloy.
Mister Donut Rep NC30
no it wasnt that deep, i think Neosophist dismantled one in years gone buy and there was a bit more than just a resistor in there!Smev wrote:Did it expose anything else? like a load of potting (rubber) and a small resistor?!!!porndoguk wrote: someone i knew also had one on theres that had road rash from a previous crash and exposed a lot of deep gouges in the alloy.
