Subframe images
Brainchild
Subframe images
Does anyone know where I could find the microfiche of how the NC30 subframe goes together with all of its other components?
About 4 months ago I stripped down my old subframe after snapping a bolt on it to put the parts on a new one, which I had on order. When the new one came I built it up, only to realise that I had previously removed a few bolts etc, from it when taking other parts from the bike
, and I now had no idea what went where
. I now also have the problem that I have a load of bolts and wire holders from elsewhere on the bike mixed up with the ones I need, and no idea of what is what
If anyone could get me some pics of a built-up subframe from all sides, that would be great.
This problem has made me think - is there a way we could have an undeleteable thread with a full database of images of a standard NC30/35, or any other V4, showing detailed, labelled images of the bikes parts? Then people with similar questions could just look at the images to find out which bit goes where and with which other parts.
Re: Subframe images
Try the rvf manual for exploded views, it should be pretty similar:
http://www.akhara.com/nc30/nc30manuals/
Brainchild
Re: Subframe images
Nope, no good. Ive got the manual for the NC30 and it does have an image of the subframe in it, but its low quality and doesn't give a 360 view, which is what I need. Thanks tho.
- oliherst
Re: Subframe images
I have a PDF in Japanese that is a very good scan of the parts manual....I also have a PDF of the service manual at home, any of that any good?
- hannakournikova
Re: Subframe images
im sure if you posted up what you need to know ppl could help out and answer for you??
failing that, i iwll be in the garage this week and have to fit a reg rec so could take a few snaps?
Brainchild
Re: Subframe images
I need images or construction tips on the rear, right side of the subframe, where the bungee hook is. Also, my box of bolts is mixed up so I need to know bolt sizes and locations too.
Anyone who could help will be praised as a saint!
davidjmclean
Re: Subframe images
I think I've got microfiches that will help you out but I don't know how to share the file with you other than sending an email!Brainchild wrote:I need images or construction tips on the rear, right side of the subframe, where the bungee hook is. Also, my box of bolts is mixed up so I need to know bolt sizes and locations too.
Send me a PM with your email address and I'll send them on.
Cheers.
Brainchild
Re: Subframe images
I've seen the microfiches, and Im afraid all of the subframe ones are of the Left side of the subframe.
