rad hose positions hybrid
				wedge
are the hoses for the rad in the same positsion if i fit a 600 motor???..just i was looking at the samco hoses for the 400 3tj???
				hunter
Re: rad hose positions hybrid
What rad are you using,I'm using the 600 rad so i use the 600 hoses.
				wedge
part of my Q really....should i use the 600 rad???...or will 400 do?
						- Kayla850
- Bike owned: Sunn Tzar S2
I used a 400 rad on mine and it was fine. They're pretty much the same size if you look at them side by side, except the 400 doesn't have the oil cooler pipes (unless you've got an SP or a 4DX). I blanked the oil cooler lines off on my 600 engine.
Some have been able to use the standard right side hose turned around, but that didn't work for me so I made up a hose using standard 3TJ stuff I had lying around and some 7/8" handlebar tube
www.projection-racing.com
www.pjcfasteners.com
				hunter
If you use the 600 rad you can use 600 hoses.like i did.
				StreetFZR
- Bike owned: 3TJ 4/6 TURBO Streetfighter.
How did you guys mount the 600 rad to the 400 frame?? I found that the mount different at the top
				hunter
Hi wedge,got sme pics for you,
This is how i mounted my 600 rad.
And this is what i used to make them,aluminium angle.
