Project NC29 spangly bastard!
PARUS
Re: Project NC29 spangly bastard!
Post by PARUS »
[quote="tanuki"]You serious??[/quote]
Of course :)) There is no reason to pay for new disk just for view, isn't it ? :poke:
tanuki
Post by tanuki »
Some shed time today swapped the disc n stuff over on the wheels but that's not important this is....
Ta.Daaaaaaaaaa
Just need to four the clutch and that really is as far as I can go until I get the head back and the casings powdercoated.
Had a go at the calipers as well, this was a quick 10 minute scrub and they have come up ok but I'm going to do them properly once I've got the pistons out.
justmartyn
Bike owned: Only 2 left.....
Post by justmartyn »
Is it wrong to be a little "aroused" at the sight of that super clean engine???? :oops:
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
What did you use to get the engine to come up as clean as that?
tanuki
Post by tanuki »
East midland blasters.
tanuki
Post by tanuki »
Right started the calipers 1 down 1 to go full scrub up new seals all round.
Cant believe the filth behind the dust seal....these calipers are 10 years old and well in need of a service makes you wonder at the state of some people's brakes on 15-20 year old bikes that have never been properly serviced.
Anyway they come up allright...
slowsteady
Bike owned: cbr400 nc29
Post by slowsteady »
[quote="selexon"]Hi Tanuki the Dyna coil bodies are a little bit bigger then the oem ones but bolt up to the same diameter spacing which makes them an ease to fit. I had to make some longer alloy spacers to lift the coils from the frame 5mm or so. The coils are 3ohm not 5ohm as I quoted before. The std plug end can be kept and new HT lead was used.
The difference you get is they are a stronger spark about 40,000 volts, which leads to a better combustion and slight difference in throttle response could be felt as well.
[img]http://i38.photobucket.com/albums/e138/ ... 0278-1.jpg[/img][/quote]
Can this be used with standard cdi
Is it just plug in
tanuki
Post by tanuki »
Yes but it's unlikely they will fit where your coils do now
tanuki
Post by tanuki »
So finally a bit more to add here we have the first draught of the subframe in ally and it's pretty good, the actual ones will be much slicker, just need to add a cous of bits and it's going back to be made up properly.
I'm also having a battery box fabricated so that it fits under the hump.
In other news Ray Stringer is seconds away from finishing my headwork so with any luck I should be picking that up at Mallory on boxing day...
Fucking yay!!
What are them brakes off Billy? Not an anniversary RW/RRX Blade?? I am fairly sure that the silver ones are for 310mm rotors... Ask me how I know..
