Can't Find Neutral NC30
Andy666
Re: Can't Find Neutral NC30
As Porndog says, while at a standstill, give the throttle a little blip as you snick up into neutral. Takes a couple of goes to get used to, but should work. If you're still rolling to a stop, it should be easier to find neutral without the need of a blip.JIGGLYB4LL wrote: And I can hardly ever get neutral when it's running so if I ever wanna stop and hop off for a second I always have to turn her off.
Doesn't cause any major issues, just got used to it but if u find and easy fix let me know!!
JIGGLYB4LL
- Bike owned: cbr125, NC30
Cheers mate, I'll give it a go :)
magg
- Bike owned: VFR400
What are using to select the gears if the lever is broken. Neutral light switches can be a bit temperamental, at least mine is, and therefore light does not always illuminate when in neutral. The clutch also tends to drag enough to make finding neutral difficult when engine is running, I find it best to try for neutral before the bike comes to a stop. There is a disc with six deep notches for the gears and a shallow one for neutral, under the cover into which the gear shift shaft feeds.
RegionX
- Bike owned: VFR400 NC30
Half a gear levermagg wrote:What are using to select the gears if the lever is broken.
8k!?porndoguk wrote:its normal you have to blip the throttle upto about 8k and drop it into neutral as the revs drop.
its the joys of owning a honda :D
2-3k is fine!!
i find if I hold mine at 3k it slips in easy
RegionX
Ok bump started, got neutral while rolling and now it finds neutral easy but it wont start, needs to get these carbs sorted...
Neosophist wrote:8k!?porndoguk wrote:its normal you have to blip the throttle upto about 8k and drop it into neutral as the revs drop.
2-3k is fine!!
magg
When removing the external gear change mechanism there will be a little accumulated oil but that's all. Bigger problem is you have to remove the water pump so if you can now find neutral I would not bother, unless you have more problems later on.
- Peter.H
I've been at the TT all week sat in traffic unable to get the nc in to neutral. This thread has saved me stalling it every time I want neutral! Amazing. Small blip of throttle and slots straight in.
Sent from my HTC One_M8 using Tapatalk
