Jacked rear 3EN1 now stand too short- Ideas?
Tonyj
Bike owned: FZR400 3EN1 88, YZFR125.GK76a
Post by Tonyj »
First of all, thanks Kayla for the jack up kit it looks much better and feels right for my lanky 6ft 2 frame :grin:
Problem I have now is when off the paddock stands and on the original stand the bike leans on an angle which is right over, I wouldnt feel comfortable leaving it. Any ideas on which sidestands are about an inch longer and should fit?
cheers Tony
barryfzr
Re: Jacked rear 3EN1 now stand too short- Ideas?
Post by barryfzr »
Try an fzr600 3he... I had the wrong one on my Genesis and it was a tad to upright for my liking. It might be knocking around if you measure yours. ;)
Tonyj
Post by Tonyj »
Hi Barry mate, ill measure the stand at work tomorrow as the bikes stored there , Kayla thought an R1 stand might fit but if theres a cheep 600he stand goin spare here then ill go for that.. :grin:
Ill pm you tomorrow if thats ok?
barryfzr
Post by barryfzr »
Yep no problem.. but no promises as my spares are spread all over. I'll do my best for you though ;) I know I swopped one round but finding it is a whole new ball game ;)
Post by Evilchicken0 »
You'll need the return springs as well ;)
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
Righty dokey, the TRX sidestand is 250mm, from the tip of the foot to the centre of the pivot, and the R1 sidestand is 15mm longer. I hope this helps!
www.projection-racing.com
www.pjcfasteners.com
Tonyj
Post by Tonyj »
Hi all, and thanks for that info Kayla, i too measured mine from the centre of the pivot and it was 230mm and Im thinking that ive probably gained about 35mm in height with the jack up kit. :grin:
So I should need another 30-35 mm extra in the stand? This means that the R1 stand will probably be the best bet from Kayla's measurements.
Or Barryfzr would your Fzr600 stand be anywhere near 265mm by any chance? ;)
cheers again for all your help guys n gal
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Post by Hogdigerdy Dog »
just as a side note ;)
have you taken into account that if the stand is longer (30-35mm) your going to have to fit some kind of bung to it to step it down from the swing arm or the chain will grind the bugger in 1/2
you'd probably be alright with a well adjusted chain but they don't stay well adjusted and don't forget there's more slack at the bottom under power than stationery
Tonyj
Post by Tonyj »
Hogdigerdy Dog I'd not considered that tbh, thanks for the advice, i def need to bear that in mind.
cheers
Tonyj
