rearsets and damper
				wedge
rearsets and damper
has anyone bought or know what rearsets you cab get????..also steering damper??...i would rather have a pair still uses the factory master cylinder and brake light switch.
				kaighn80
Re: rearsets and damper
i bought a cheap yoshi copy rear set and they use the standard stuff, not badly made either, not great but not bad, its the price that did it though, you could buy 5 sets of the cheap ones for the price of a good set.
SES do a pair for the 3TJ they use the standard ger too. The can will touch down first though
				Taggyd
ive got a 'universal' damper, it goes around the fork leg and is secured onto the metal bracket up on the side near the front of the frame. you can drill and tap the frame to mount them too. my road frame had the holes from where it was used as a race bike.
I've got a generic damper if you want one
				wedge
thanks for the offer,im watching one on the fleabay at the moment....what i really want is a factory road sp seat unit..
				Taggyd
racombi weiss, i think that's how you spell it, do replica ones in gel-coat white. not bad bits of kit.
				edsashed
hi evilchicken i would be intrested in the damper if it comes with a fitting kit etc
sorry no fitting kit, but you could ask Kayla to make you one
						- cagiva996
just a thought about the steering damper,do you really need one? my 3tj2 has never tank slapped or got unstable on road or track and the roads on the iow are awfull,even with the yokes pulled thru the yokes either 5 or 10mm,the rear raised by 8mm, and racy track tyres fitted its never got out of shape.not trying to be a killjoy but you could save the cash and spend it on something else that you may really need.or perhaps i aint trying hard enough!
