Bike wont rev over 5k, help!!
Tom1
- Bike owned: 1990 VFR400 NC30
Re: Bike wont rev over 5k, help!!
Thanks for the quick reply.
And that will de-restrict the bike?
Well it'll let it rev over 5500rpm.
JDM bikes were limited to 180km/h.
Once it's running again, if you find it stops dead at around 180km/h then it's still restricted.
A common way of desrestricting them is to open the speedo (it's only screwed together, not sealed so comes apart easy)
You'll see a metal disc that contacts sensors when the needle hits 180km/h. If you manually turn the needle to around 180km/h you'll soon know the disc as it moves inbetween two sensors. It's probably around 3cm long.
This metal disc is only tacked on with two rivits and a small flat bladed screwdriver will pop it off, and no more restriction. You must still leave the speedo-board connected so the bike thinks the speedo sensor is still inplace but with no disc to trigger it then device will never kick in.
You can also buy plug-in boxes and other gear but this is the easiest / chepeast way to do it and it's undetectable unless you take the speedo apart again.
Tom1
Right so even though i have a koso speedo, i still need to connect the the speedo board to the bike, but it wont be restricted to 180km/h..
Sorry ive never understood it.
Thanks again
Thanks again
Thats your problem then!Tom1 wrote:Right so even though i have a koso speedo, i still need to connect the the speedo board to the bike, but it wont be restricted to 180km/h..
Thanks again
You don't have the speedo board connected.
If your not using the original speedo you can use a resistor in place of the large (in comparission) speedo board.
Find the plug thats by your clocks that originally plugged into the speedo clocks.
Get a 2.2k ohm resistor.. about 6p from maplins.
Here's a high-res pic on how to do it. but all you do is connect the resistor to the two outer wires in that plug.. brown/black and orange blue I believe.. You can cut the plug off and solder it straight to the wires if you want, just make sure to use some heat-shrink tube to fully insulate it.
http://www.400greybike.com/files/NC30%2 ... 20how2.jpg
Tom1
Thats fantastic! Thanks a lot, ill let you lads know how i get on!
magg
- Bike owned: VFR400
There is a resistor bypass mod that can substitute for the speedo sensor if you prefer.
magg wrote:There is a resistor bypass mod that can substitute for the speedo sensor if you prefer.
Read my original post, it's already covered.Find the plug thats by your clocks that originally plugged into the speedo clocks.
magg
My apologies I missed the second page of the post.
Tom1
So with this high res pic, all i need to do it the Speedo plug end. I dont need to do the resistor mod at cdi end do i?
magg
Yes, you put the resistor at one end or the other but not both.
