Engine Number
				MarkT
Engine Number
I really need to find out engine no on my bike to identify what it is? Can you tell me where it is please? Thanks
				dobbslc
Re: Engine Number
It's on a flat plate about 15mm x 45mm long on the top of the crankcase,
just above the clutch cover I think.
It will probably only say 1WG though.
Dobbs.
Dobbs.
				MarkT
Re: Engine Number
Thanks very much!
Re: Engine Number
Yup - unhelpfully all the 400 engines are stamped 1WG and nothing else
				MarkT
Re: Engine Number
Nope no number above clutch cover? Only number I can find is on front of engine says 1wg 998cc?
						- Hogdigerdy Dog
Re: Engine Number
as dobbslc says "It's on a flat plate about 15mm x 45mm long on the top of the crankcase just above the clutch cover"MarkT wrote:Nope no number above clutch cover? Only number I can find is on front of engine says 1wg 998cc?
which it is but you can't see it without having the tank off as as it's inside the frame spar on top of the crankcase
998cc that's some big bore, it's not a 3tj/Ducati hybred is it
 have you counted the cylinders
				MarkT
Re: Engine Number
998 -  can't even read properly now! Thanks for that, really must find out what most of the engine is!
The word Ducati makes me feel ill! After two that was enough!
