charging fault now fixed
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster »
HI again got a problem with my nc30 again. CHArging 14.8 when lights are off but starts draining battery with lights on any idea's Phil
Last edited by V4beermonster on Thu Sep 29, 2011 11:32 am, edited 1 time in total.
magg
Bike owned: VFR400
Re: charging fault
Post by magg »
How do you know lights on drains the battery.
Re: charging fault
Post by Neosophist »
Battery voltages please.
Lights off:
Engine at idle
Engine at 5000rpm
Lights on:
Engine at idle
Engine at 5000rpm
V4beermonster
Re: charging fault
will get charge rates to you have checked altinator all checks out reg/rect is new old 1 burnt out and replaced plug,lights off is 14.8 @battery that drops with side lights on and then with main lights on you can watch the volts on meter dropping ie 12.5-12.4-12.2 ect and drops below 12 whilst running. it like it not charging with the lights on
Re: charging fault
What reg-rec did you replace it with?
V4beermonster
Re: charging fault
A after market 1 from cbr
V4beermonster
Re: charging fault now fixed
ok guys here's your info battery = 12.25v so thats fucked, idle lights off = 14.20v :grin: 5000rpm =14.9v :grin: Lights on idle = 12.15v :( 5000rpm = 12.30 :( so put another ok battery on and battery = 12.8 ok, idle =14.2 ;) 5000rpm = 14.9 :grin: lights on idle = 12.20v :( 5000rpm =12.60 :( so checked everything else altinator ac = 47,48,49 ac/v at yellows so thats good, tested resistance all at 00.6 again good so put put used r6 reg/rect on in replace of the new aftermarket 1 and we have battery = 12.80v 8-) idle lights off = 14.25v 8-) 5000rpm = 14.80v 8-) lights on idle 13.95v 8-) 5000 rpm = 14.25v with high beam ect all on so looks like a duff new reg/rect cheers for input Phil
Yep.
CBR aftermarket regulator would be the problem.
Going to assume it's one of the cheap 20gbp Chinese knock offs?
There shite!
The R6 r/r is fantastic value for money.. 2nd hand ones can be had delivered for around 20gbp if you shop hard enough.
V4beermonster
yeah chinese shit m8, why would it not charge while lights are on?
makz2008
Bike owned: NC30, NC35
Post by makz2008 »
congrats on getting the problem sorted!
ive got the same problem and have recently purchased a R6 reg
problem is i dont have a clue what i need to do with the wiring coz the R6 reg didnt come with any wires on it
could anyone tell me which colours from the original wiring i would need to connect to which pin on the R6?
