Billing's Bikes
alexwitham
Bike owned: 675R, GSXR6, NC30
Re: Billing's Bikes
Post by alexwitham »
Mine doesn't do this either.
porndoguk
Re: Billing's Bikes
Post by porndoguk »
alexwitham wrote:Mine doesn't do this either.
nore mine, not that it bothers me!
Re: Billing's Bikes
Might just be 35's that do it then
BillingCBR
Re: Billing's Bikes
Post by BillingCBR »
Maybe mate, not THAT fussed, but would like it, would be cool for it to do that lol
BillingCBR
Re: Billing's Bikes
Here she is as she stands, will be looking to have the nosecone sprayed up this month, as have been working hard doing loads of extra to earn some more money to spend on the bike lol
And I fitted the TSR rearsets, little confused as to how the rear master cylinder is supposed to fit on properly, is it possible to get a smaller one at all?
Cammo
Re: Billing's Bikes
Post by Cammo »
BillingCBR wrote: And I fitted the TSR rearsets, little confused as to how the rear master cylinder is supposed to fit on properly, is it possible to get a smaller one at all?
It doesn't appear that you'll be able to fit to the correct side (inboard) of the rearset with that brake light pressure line in place and without packing it with some spacers.
BillingCBR
Re: Billing's Bikes
It won't go inboard anyway :( the m/c wouldn't line up with the brake lever :down:
Anyway, I've been busy, RO RC30 style seat unit fitted, minimum of fuss, just need to tidy up some cast lines, and one chip where the drill slipped :(
BillingCBR
Re: Billing's Bikes
I've been thinking about the hydraulic clutch conversion I talked about earlier in the thread, I have the complete assembly from an NC21 (£10 from Japan!) but no way to mount it to the NC35 motor as it has a cable operated clutch. I was reading Practical Sportbike earlier and saw the feature on the VF400F they had recently, and noticed that the VF uses a hydraulic clutch like the NC21, so after a quick trawl on ebay I noticed there was an engine for sale, stating it was an NC13 motor, it's common knowledge that all of the VFR's have engine numbers beginning NC13E, so picked up a sprocket cover from a VF :up: Here's hoping it will fit ok, I'll update as and when :)
Re: Billing's Bikes
Fingers crossed, mohags and royster were sorting out a hydrulic clutch, might be worth tapping them up for some advice
BillingCBR
Re: Billing's Bikes
I remember, I think all I need apart from cutting the sprocket cover up is a custom pushrod, but will sort that out when the time comes :D
I have a couple of bits being sorted, Scitsu temperature gauge, modified caliper carrier link and spacers, pics when they arrive :)
