URGENT again! bike wont start now...??
Andy_Edw
Re: URGENT again! bike wont start now...??
Post by Andy_Edw »
xivlia wrote:another thing. cleaned my spark plugs by submergeing them in non-leaded petrol for 4 days...could that have broken the plugs?
I'm sorry but that made laugh a fair bit! :grin:
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
:D im actually laughing about it now too. i thought i fucked the whole bike up. but its only plugs!
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
Dry them out by heating up on the gas ring or hot air gun and check for a spark, wetted plugs can often be made to work.
Worth a try.
xivlia
Post by xivlia »
ok. can anyone tell me what that thin hose in the picture is for?
is it attached at the bottom? I think it is the airbox breather - you don't need it
xivlia
Post by xivlia »
yeah it goes down to the bottom. but ive alreaddy attached my airbox breather.. and i checked my plugs by removing them and connecting the HT lead onto it and while holding it in my hand i pressed ignition and they are not sparking, so it must be the plugs. ive also check my carbs there is fuel inside them as i tested it by unscrewing the drain valve and fuel comes out.
you have to earth the plugs to get them to spark, touch the socket flats on an engine bolt...then try it - try not to shock yourself
magg
Bike owned: VFR400
Post by magg »
Might I suggest that the hose without a home is part of the tank breather system. My hard to follow hose and wiring layout diagram indicates that the tank vent hose runs to a three way joiner and from there a separate hose runs down each side of the engine, why I have no idea. Cannot guarantee my diagram applies to all NC30 variants but worth a look.
No spark may also mean NO SPARK, not dud plugs. Try removing one spark plug and inserting a piece of wire into a plug cap and spacing the wire 5 mm from the frame and hitting the start button. If there is spark it should be visible as it jumps to frame. KEEP FINGERS AWAY!!
xivlia
Post by xivlia »
okay, ive almost got it to start now. engine fires and dies. but its getting closer and closer...but my battery has almost died now..i dont have a charger. would i be able to charge it with my dads car or is car batteries enough to blow bike battries?
Andy_Edw
Post by Andy_Edw »
Try bump it?
