3TJ Fan problems and overheating
MarkT
Post by MarkT »
Ever since a few weeks ago and it was revving in the workshop, it boiled it's coolant out the expansion tank. Still trying to get it right when it started dripping on the floor again the temp gauge was at the middle but the fan was not working?
I have to take the fairing off (both sides) but is the fan connector easy to find and were on earth is the fuses!
Thanks mark
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: 3TJ Fan problems and overheating
Post by Taggyd »
undo the fan bolts and as you drop it away follow the wires, you will see the connector, its just up at the front of the bike. dead easy! fuses are up at the rear under left side iirc!
make sure the air is all out of the rad as well. its been covered on here i think!
MarkT
Post by MarkT »
Thanks very much I presume the sensors are on the right of the bike cos I'll need to test them?
Thanks again
Mark
could easily be a duff rad cap...
MarkT
Post by MarkT »
Thanks good point!
dobbslc
Bike owned: 3TJRRSP TRX850 XV750 cafe
Post by dobbslc »
Yes
rad cap, rad cap, rad cap............... :whistle:
Always worth trying.
MarkT
Post by MarkT »
Thank you all in takin time to reply shall hopefully get one to-day
Thanks again!
MarkT
Post by MarkT »
Ok new cap £30 !!! no difference gauge just goes over the middle and water (very hot) comes out of overflow. Earthed the gauge wire and the gauge does a sweep of the dial. I have wired the fan to be on all the time and the gauge stays about quarter off cold and stays there, no overheating even when the bike is revving so I think that rules out head gasket and the gauge is not reading right? The sensor for the gauge is £30!! And the fansensor which I have bought which was another £30!! I just can't see how to get at it to replace it? There is another post asking about that I just can't see how you do it?
Taggyd
Post by Taggyd »
you could just wire it to a switch and flick it on when it looks like it might be getting warm!
MarkT
Post by MarkT »
Thank you, yes I wondered about that, might have to do that!
Thanks for replying!
