NC30 HRC Replica Suspension Linkage
- RickOliver
Go look here...
http://www.400greybike.info/newforum/vi ... a&start=10" onclick="window.open(this.href);return false;
Rick
Rick
Re: NC30 HRC Replica Suspension Linkage
Very, very nice! Does it come fitted with bearings Rick?
Maybe x-mas will be nice to me this year (although I have been a pretty bad kid!).
We'll see.
We'll see.
- RickOliver
Yes, comes fitted with new bearings and seals, you just have to transfer the inner sleeves from your original linkage.
I can supply new sleeves as well if required, but being genuine Honda parts it will add £30 to the cost...
Ok i'll be the first to ask
apart from looking dead trick whats the benefits of using this?
- RickOliver
The HRC manual doesn`t say, but I sat down with my protractor a year or two back & worked out that it 1) jacks up the back end without having to increase the shock length 2) effectively increases the spring rate by changing the leverage ratio between the swingarm and the shock and 3) also increases the `rising rate` effect of the linkage.
- royster81
i'll be the first to ask the price please ...
hunter
royster81,the price can be found here.
/viewtopic.php?f=24&t=13089&st=0&sk=t&sd=a&start=10
999Gomerz
- Bike owned: Hondas, Ducati, Suzuki, Vespa
Hi Rick,
You mentioned that it increases the rising rate.
Do you mean that it makes the rate more progressive or digressive?
Or does make it more of a flat rate link?
Cheers,
Adrian
Cheers,
Adrian
