Scratched speedo surround.
Marly
- Bike owned: NC30....
Have you guys got any advice on tidying up my speedo surround
I cant stop the clutch adjuster scratching the edge of the clock without adjusting it so it's very uncomforatble to ride.
I can't seem to find a happy medium.
Any advice? I gather this is a common issue.
Thanks in advance.
Thanks in advance.
- alexwitham
Re: Scratched speedo surround.
You should be able to loosen the clutch perch and move it up slightly, you only need to raise it a few MM.
- CRM
Hi Marly, your right its common and actually normal but annoying all the same.
try moving the perch outwards a couple of extra mm, so its v tight up to the grip, that may give you the adjustment you need
Marly
Thanks for the info guys.
Will see if I can get it any further out towards the grip. I think a part of the perch knocks against the switchgear if it's too close tho.
If I move it any higher up, it gets quite painful after a long ride.
I'd always wondered why the PO had the levers up so high!
The next thing is, once I've managed to get the clearence, can anyone recommend a way to tidy up the surround?
Thanks.
Thanks.
- Hadies
I have my clutch perch and lever also pointing up at an unsightly angle. I would love for it to be pointing down a little like my brake lever. Is there nothing that can be done with the clock brackets to shift the speedo back a little?
- Deviant400
my clock surround was badly scuffed, i took the clocks off then took the cover off , i put some fine grit , think it was about 400 grit wet and dry and gaffa taped it to a piece of glass and slowly rubbed it around in circles on the glass , (i put a circle of gaffa on the clock glass just in case i scratched it ) then went to about 600 grit to smooth it off a bit more i also went around the edge a bit too, it didnt remove the scuff totally but made a great improvment and it looks a lot better than it did
viewtopic.php?f=62&t=27307
If it's hitting the speedo it's not on correctly.
This is often the cause of crash damage, it knocks the clutch lever out of alignment.
Fortuantly, Honda in their wisdom put Punch Marks in everything to help you line it up.
If you look at the clutch lever mounting bracket (it has 2 8mm head M6 bolts in it) and loosen these off.
On the actual handlebar there is a small punch mark.. the seam of the clutch leaver bracket should line up with this punch mark.
Marly
Thanks Neo.
Will take a look for this punch mark later.
So, the next question, if I manage to get the lever aligned so it doesn't touch the speedo, is there any way to replace just the top part of that speedo?
Marly
Found the punch mark.
I'm not too far away from it (about 1mm at most).
The problem is, the nearer to the punch I get, the more uncomfortable it is.
I may see if I can get lock nut with a smaller diameter.
