Martin
Post by Martin »
The RC30/RC45 one would work IF you managed to find the F3-TT tacho healer, good luck on that one. I've been looking for 3 years for one before I get the Tacho as it's useless without one :down: If you don't mind speedy would you be able to sort an overlay out for me also please? Obviously I'll pay you for your time and effort.
Too spensiff!!!
What does the tacho healer actually do? could the output from the cdi not be adjusted somehow through the ignitech software? that is assuming you have a ignitech
Martin
Post by Martin »
In combo with the HRC CDI it makes the tacho accurate so theoretically the Ignitech should do the same thing I guess. You can be the guinea pig for that one mate ;-)
Too spensiff!!!
Hmmm wheres stephens RC45 when you need it :whistle:
Hold on a minute, your telling me you dont have a HRC CDI? martin i find that very hard to belive from such a HRC bod that you are ;)
Martin
Post by Martin »
Here you go.
Too spensiff!!!
Speedy
Bike owned: RVF400RR, ER6n
Post by Speedy »
Drunkn Munky wrote: As for that tacho, id really love a HRC one but as always there a little thin on the ground. I did find a RC30 HRC one but it was very tatty and im not 100% sure it'll work. I think i might have to settle for one of those overlays you've knocked up speedy ;)
Yeah, you can have one of my copies no probs; I've tweeked it some more and it's pretty damn good, even if I say so myself! Ideally though, we would have copies of it in proper plastic rather than printed paper!...
@ Martin: Do you want me to send you a printed copy or just email you the Adobe Illustrator file, so you can print it at home?
Here's what it looks like now:
There is a similar print on the reverse too; the idea behind that, is so that hopefully less/no light will shine through the black parts at night time and only the white bits will light up!...
Martin
Post by Martin »
Just the file will be cool if you could do that. Email is m.meegan77 at googlemail.com thanks chum :smile:
Too spensiff!!!
Just a thought but how about a group order of some proper faces like the ones porndog has just arranged?
Just thinking out the box here but if we did would it be possible to get them to make the dials without the 1 and 2k markings and put a stop pin at the 3k mark then physically turn the tacho so the 3k mark is where the 1k mark is now? A bit blue peter but in my head at this stupidly early hour in the morning i think it'll work :)
Martin
Post by Martin »
That's exactly what I was going to be doing with this one Tony. However, I think the majority of people would rather have the 1k and 2k symbol so they can set their idle speed properly. Having 1k and 2k symbols on mine is a waste of time as my bike doesn't idle properly that low with HRC carbs.
Too spensiff!!!
Speedy
Post by Speedy »
I'm in for a group order on the proper faces; question is, can the makers copy exactly what we want? :pray: :pray:
Having the scale begin at 3k would look cool and modifying the faces I've made is certainly do-able, but it would mean having our bikes ticking over possibly too high!?
@ Martin, file in your inbox! :smile:
