STARTER MOTOR COMPATIBILITY
MrTadSlow
- Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
First port of call to ask for some advice !!
I'm starting my conversion on my 3tj at last ! & would like some advice on starter motors.
Will the starter motor from the 3t go into the 4jh motor ?? or do i have to sauce one for the appropriate engine ?.
I've looked on BikeBandit.com & there codes mach, but i'm lead to believe they are BikeBandit codes and not the Yamaha ones so some help would be great Please.
Taggyd
Re: STARTER MOTOR COMPATIBILITY
stick it in and try it? if it doesn't work then you know you need a different one!
I reckon they'll be the same.
dobbslc
Pretty sure the crankcases are the same as long as the gear inside is the same diameter a 3tj one should work.
MrTadSlow
When its cooled down a bit in my shed I'll go out & have a go, its just to hot at the sec !!
MrTadSlow
I said to my better half what i was going to do with the advice from Taggy & seconded by a dude called Evilchicken and she looked Quite Shocked.
After i came back the shed & Explained again in her native tongue of Janner..."Plymouth" she understood.
So thank to all a Yamaha FZR 600r 4jh starter motor fits a Yamaha 400rr 3tj.
