rvf fairing on a vfr
sheepus7
Bike owned: VFR 400
Post by sheepus7 »
is it a staight swap to put nc35 fairings on a nc30
thanks
sean
dave6970
Bike owned: SP-1, NC30
Re: rvf fairing on a vfr
Post by dave6970 »
Not 100% sure but I think the fairing fixing bolt is lower on the RVF
sheepus7
Bike owned: VFR 400
Post by sheepus7 »
dave6970 wrote:Not 100% sure but I think the fairing fixing bolt is lower on the RVF
ok thanks
CRM
Admin NWAA
Admin NWAA
Post by CRM »
lowers are the same item essentially, nose mounts different as do the mids.
so you could use 35 lowers on a 30 but changing the whole lot is not a simple bolt on onto the 30 bracket on the front.
seat panels are different too and would require a 35 subframe to fit.
sheepus7
Bike owned: VFR 400
Post by sheepus7 »
CRM wrote:lowers are the same item essentially, nose mounts different as do the mids.
ok thanks for the help
p.s. where abouts in cheshire are you from
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Between chester and runcorn
sheepus7
Bike owned: VFR 400
Post by sheepus7 »
CRM wrote:Between chester and runcorn
not far from me then 8-)
