fzr400 restriction washers
dt50james
anyone got the washers for sale?
if not. i have the size of the holes thats required but no one says where to drill the holes. how far off centre?
its a 3tj model im looking at getting and will need them.
just going to get it dyno'd after ive fitted them like a good boy.
Re: fzr400 restriction washers
Your insurance will be void if you take them out while under restriction and there are police that read the forums.
dt50james
what metal do people use? just steel? alloy?
could i just manufacture them myself or are there people that have some in there garage i can fit?
dt50james
let me know if anyone has any as i will need them soon as i get the bike
StreetFZR
- Bike owned: 3TJ 4/6 TURBO Streetfighter.
You will need them fitted by a licensed dealer. Needs the certificate stamped for your insurance.dt50james wrote:what metal do people use? just steel? alloy?
They don't need to be fitted by a dealer but you have to prove they're in there and that bike puts out 33hp, a dyno print out should be enough. If an insurance company want confirmation from a garage then you can take the bike there and take the cabs off yourself if you like, the garage will charge you for the letter.
dt50james
yes i dont mind that at all. Just need the washers. Has anyone got a restricted bike they dont mind popping the washers out for me to copy?
FZR400
- Bike owned: Yamaha FZR400 RR 3TJ
This is from when i took out my 3tj restriction washers.
I didnt have any Verniers that day so the measurements are pretty accurate but not 100%
Total Diameter - 38mm
Hole Diameter - 13mm
Thickness Approx 1mm
dt50james
should the outer diameter of the washers be 38.5? or 37.5? ive seen two write ups.
are they critical or as long as you have two holes to size its ok?
FZR400
Just to be awkward mine seem to be 38mm exactly!
The position of the hole is important, it needs to be that low so when the throttle starts to open the air/fuel can be drawn through the closest point to it
