Bottom rad fan
- wangwang
Bottom rad fan
Is there a difference between the NC30 and NC35 bottom rad fan? if so what is different?
Wang
Wang
Re: Bottom rad fan
yes, different, but not sure what!
- BillingCBR
Re: Bottom rad fan
force-v4 should be able to elaborate, I believe he has first hand experience of the differences
- CRM
Re: Bottom rad fan
everything essentially is the same but the wiring is different.
if i recall the RVF has 3 wires, the NC has 2. i cant remember if the RVF uses an extra earth or something.
- force-v4
Re: Bottom rad fan
I have and couldnt make it work (nc35 fan on an nc30) hooked all the wires up & doubled up on an earth but it wouldnt have it.
The plug is different as well, the nc35 has just 2 wires in the 3 wire housing & the nc30 has 3 wires.
I couldnt be arsed to play around with it after that, as i had a spare nc30 fan but im no electrician.
