Headlights
- Bike owned: cbr1000rr, kawasaki kle500
Headlights
Help!
I've got a GK76A and the headlights are not working. I've changed the bulbs and nothing, i've checked the wiring and found two what i would call side light bulb connectors with nothing to connect to them, all the wiring had been cut and connected back together so i got anther switch and wiring and still nothing. So i got hold of some side lights off flee bay (even though there's no room for them in the headlight / fairing) hooked them up and now i get full beam but nothing else?
Any ideas?
looking at the parts catalog there might be two types, one with seperate sides
JL
Any ideas?
JL
- Bike owned: GK76SP & ER6F
Re: Headlights
The GK76a has headlights that are driven by a relay under the seat, perhaps that is not working correctly.
When you turn the ignition on, you can hear a very faint click as the headlight relay engages, so check for that first. If that's working, then you should check the little fuses next to the headlight relay.
I believe the wiring diagram is available on the 400gb home page, so you'll have to go through that to make sure there are no faults like a short anywhere.
