Track bike build'08,'09,'10,'11,'12,13.........
chrisja2
Bike owned: nc29 trackbike
Re: Track bike build'08,'09, winter changes '10
Post by chrisja2 »
tanuki wrote:Mate I'm going to need your help when it comes to swapping over a swingarm as I've never done it.
Well that makes two of us then, im sure we can sort it. Aly clip ons eh, they are next on my list of wants. When do you need the frame? Im swopping out my frame for the powder coated one at some point. All numbers are in tact but no V5. Yours if you want it?
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
tanuki wrote:I'm going to swap the SP1 calipers that are on the NSR and use them with the standard RVF M/C
RVF master cylinder is 14mm, you need 5/8" for the later bigger calipers or you will have spongey brakes with too-long lever travel.
chrisja2
Post by chrisja2 »
VTR calipers serviced and fitted, brakes bled but might have a leaky nipple :down:
amorti
Regular Member
Post by amorti »
chrisja2 wrote:VTR calipers serviced and fitted, brakes bled but might have a leaky nipple :down:
Certainly looking good with those calipers, trust the m/c worked well.
Leaky nipple? Is the seat is damaged you've got a problem :-( .
tanuki
Post by tanuki »
cant believe you sold them forks so quickly
cajun
Bike owned: MC22, NC29,NC35, 2 FZR400's
Re: Track bike build'08,'09,'10,'11.........
Post by cajun »
If you are refering to the bleed nipple then get some white plumbers thread tape. Works wonders for about a buck.
chrisja2
Post by chrisja2 »
cajun wrote:If you are refering to the bleed nipple then get some white plumbers thread tape. Works wonders for about a buck.
Is PTFE tape ok with brake fluid?
tanuki
Post by tanuki »
What's the worst that could happen :o
cajun
Post by cajun »
I would assume so as I've done it a bunch of times in the past and doesn't leak.
chrisja2
Post by chrisja2 »
Well with Donington a week away im still awaiting some prolite discs i won on ebay and the SBS sintered pads ive ordered. Fitted new iridium plugs though, so fingers crossed these other bits turn up asap. Need to drill and fit a fibreglass front mudguard then should be ok to test. :whistle:
