Update eletrical problem..
Chrisfizzer
Hi ive done a post about how I needed a new regulator rectifier well this is an update, Ive purchased a new regulator rectifier fitted it.. The bike ran lights working, indicators no problems accept for the fact when I give the bike more than half revs it dies down and seems to go to 2 Cylinders, Tried using another battery wasnt the problem now it wont start!?
dobbslc
Re: Update eletrical problem..
If the bike was ok before you ran out of fuel you might have crap in the carbs from any rust, dirt, water in the bottom of the tank. Try cleaning the carbs and tank out, put in a new filter and try that, it maybe that your draining the battery trying the start it when the carbs aren't right.
