Newbie in need of help!
Carcass
Bike owned: Srad750, Nc29
Post by Carcass »
Hi all i recently bought a vfr 400R nc24 as a big project, the rear disc was cracked so i bought a replacement disc.
When i went to fit it, i found i could not remove the rear hub {after removing the 36mm nut and sprocket carrier} to get to the brake disc :cry:
If anyone could give some info on how to remove it {and what im doing wrong} that would be great.
Cheers Chris
Cammo
Re: Newbie in need of help!
Post by Cammo »
Silly point perhaps, but... have you taken the wheel off?
Sometimes they need a good whack as they tend to stick after time.
I'll guess a circlip on the wheel side preventing you taking it off.
not got a 24 but am sure someone will be out soon to let you know
Welcome to the forum as well ;)
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
do you not need to remove the hub nut from thew other side(46mm)
im not entirely sure as its been a while
Carcass
Post by Carcass »
wullvfr wrote:do you not need to remove the hub nut from thew other side(46mm)
I don't think there is one, Here are some photos of how far I've got {see links} When i went to buy another disc {someone was breaking a bike} he took the giant cir clip off and the whole bearing holder {I think that's what its called} came out and he still couldn't get the hub out {or the disc over the bearing holder}
http://vfrworld.com/forums/attachments/ ... g_1104.jpg" onclick="window.open(this.href);return false;
http://vfrworld.com/forums/attachments/ ... g_1102.jpg" onclick="window.open(this.href);return false;
http://vfrworld.com/forums/attachments/ ... g_1103.jpg" onclick="window.open(this.href);return false;
hannakournikova
Bike owned: NC30, NC35 & SP2
Post by hannakournikova »
you need to log in to see those pictures mate
Carcass
Post by Carcass »
hannakournikova wrote:you need to log in to see those pictures mate
Just made a photobucket account
http://i46.photobucket.com/albums/f115/ ... G_1102.jpg" onclick="window.open(this.href);return false;
http://i46.photobucket.com/albums/f115/ ... G_1103.jpg" onclick="window.open(this.href);return false;
http://i46.photobucket.com/albums/f115/ ... G_1104.jpg" onclick="window.open(this.href);return false;
Have you any from the disc side? If that splined bit has been pulled through slightly I guess that a ciurclip on the back side is stopping it coming through? Have you
Looks like the disc can undo anyways? Is access that bad?
hmm...a good one this matey :?
Post by Neosophist »
is that a circlip by the disc?
spooky
Bike owned: nc24
Post by spooky »
http://www.vfr400.pwp.blueyonder.co.uk/parts.html" onclick="window.open(this.href);return false;
click on the link above for the microfish of the nc24 mate. It helps see what way the parts go together.
