starter clutch
Carter
starter clutch
Post by Carter »
well, i've got the 400 running at long last! only thing is the starter clutch is slipping and i can only bump it off, don't suppose any one know where i can get the kit from?
joe 90
Re: starter clutch
Post by joe 90 »
try
http://www.cmsnl.com/suzuki-gsf400-1991 ... IG-08.html" onclick="window.open(this.href);return false;
they list one for the bandit
ill check the part numbers as they might be the same for the gk76
if yours is a 73 i dont know if theyll fit
M1KE
Re: starter clutch
Post by M1KE »
73 is the same engine as the bandit 76 isnt technically the same although some parts are common.
Carter
Re: starter clutch
Post by Carter »
joe 90 wrote:try
mine's a 76, so these should fit then??
M1KE
Re: starter clutch
Post by M1KE »
:ugeek: dunno
Carter
Re: starter clutch
Post by Carter »
well.....ordered so I'm about to find out :D
gsxr400 racer
Re: starter clutch
Post by gsxr400 racer »
your good
