Kevlar exhaust sleeves, bulk order needed
Been talking with carbonmods and they said they can do a minimum order of 6M in any weave inc carbon/kevlar. No price as yet but id guess it'll be slightly more than the stock carbon tubes you can buy.
Size wise there be replica's of the TSR SP1 cans, about 98mm diameter i think, anyone want in?
marcus57
Re: Kevlar exhaust sleeves, bulk order needed
typical, i end up going down the carbon parts route and then this turns up, what sort of price is carbon tube?
- banoffee
Tried thembanoffee wrote:http://www.pjengineering.co.uk/products.asp?cat=8
Right got a price for the carbon/kevlar tube, 99mm ID and 0.8mm thick. £80.50 per metre totalling £483 for the 6M +VAT
Cans are 400mm long so that will get 15 sleeves from the 6M making them £32.20 each +VAT
I'll take 4 sleeves so anyone else interested?
Obviously your going to need end caps etc to make a complete can but these are readily available.
- micpec
Tony, nice find! Are these an direct replacements sleeve as per size and diameter of the TSR SP1 cans? If that is the case...I need 2 sleeves!
But maybe another 2 sleeves extra.
There actually 99.2mm ID which is one of the standard mandrel's they use which is handy as thats pretty much bang on the TSR SP1 size give or take 0.2mm.
Hopefully ANR wil do end caps to in that size although i think TI endcaps are going to be impossible to source
nubs
I would be interested in two sleeves.
are the sleeves being sent out as sheets and we have to form them?
im thinking i may recover the oval tyga can in kevlar?
hmmmmmmmmmm?
hmmmmmmmmmm?
Nope there be supplied as a tube ready for assembly.
For all those interested please note the funds or some kind of deposit will be needed up front, the last thing i need is £500 worth of kevlar tube as people have changed their minds so if your serious PM me.
Lead time will be 4 weeks so please bear that in mind.
do you think there could be a small posibilty i could have an oval one to fit over the Tyga canDrunkn Munky wrote:Nope there be supplied as a tube ready for assembly.
PWEEEEASE?
