GK76A CDI on a 400 Bandit??
- Bike owned: ZX10R, SZR660, R6
Re: GK76A CDI on a 400 Bandit??
Ahh i see!! I've not taken one of these engines apart before and assumed wrong. (you know what they say about assuming)Variablevalves suck wrote:nothing to do with the genny, its the trigger under the near side cover, they change the timing to suit the different cdi.
So by the sounds of it i need the trigger from the earlier bandit then to match the cdi? not sure what came with the cdi now as its at home and i'm not! I'm fairly sure that part was included. i also got some gears and cogs?? Anyone shed any light on what these are for? I haven't started fiddling with it properly yet as i've been busy with other projects!!
Dont suppose anyone has a parts diagram for these engines??
Just to clarify the trigger is what the cable going into the nearside cover connects to and it plugs into the loom??
Should be an engine section in the manual hosted on banditalley. The cogs will be starter gears i imagine.
- Bike owned: Gsf400
Let me know if your after my Ignition module. £30 and its yours.
Mike
Mike
- Variablevalves suck
like Mike sayz they are the starter gears. Take a look at reggit's post about the B4 as it has pictures.
Chris.
Chris.
For some reason it wont let me log in to bandit alley. Says my acount has not been approved. Can someone do mea favour and email an admin on there for me? same username as here.M1KE wrote:Should be an engine section in the manual hosted on banditalley. The cogs will be starter gears i imagine.
Thanks Griff
Checked the cdi package earlier and it does have the trigger so fingers crossed.
Maderdog i'll keep you in mind if thats ok.
Thanks Griff
PS just been reading on bandit alley about diy cdi repairs! I'm not too bad with a soldering iron (did my Frontera dash with excellent results) and i can get the capacitors for less than £1 so sod it i'll give that a go! Nothing to lose as the cdi is knackered anyway!!
Thanks Griff
