rubber headlamp surrounds
- Deviant400
does anyone know where i can get some of the rubber head light "gasket things " (i dunno what there called
) that go around the lamps to behind the fairing to stop the light leaking out >
viewtopic.php?f=62&t=27307
- royster81
Re: rubber headlamp surrounds
yeah , honda.
got these a few months ago and they were only £6odd each and you can get them through rick, sorted !
razor400
Go to halfords and buy a cheap bike inner tube, some glue and make your own, easy and cheap.
- micpec
This can be ordered, it is honda part no. 33106-MR8-000.
Spike16
Cheepest inner tube at halfords is £5, so ur saving £7 but it will look alot better using honda parts
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
How would the cutout pattern look like for this part?
- banoffee
anyone get theirs to fit and 100% seal the light out properly? having taken the bike apart and put back together, I've tried them in every given angle!
- Deviant400
made my own in the end from inner tube and patch glue , seal perfect
cbr400rrn
- Bike owned: NC29 CBR600F
Bought mine from davidsilverspares and they are about a 95% perfect fit although the left and right ones are different part numbers. Left = 33156-ky1-300, Right = 33106-ky1-300 are the Honda part numbers (this is for an nc29 dont know if the nc30 ones are the same)
I found that the nc29 rubbers (had some spares sitting around) actually work better on the nc30 than the standard ones....
I've also made them out of bike inner tube before, cut a length out stapled the ends together and they worked better than standard.
