UK FZR400RR
nc23rider
Bike owned: zxr400
UK FZR400RR
Post by nc23rider »
Are all fzr400 3tj imports,or are they uk versions as well ?
If so,whats the difference ?
Thanks,steve.
Re: UK FZR400RR
UK bikes are a 4DX instead of a 3TJ.
Apart from that...I know nothing!!
ARn13
Re: UK FZR400RR
Post by ARn13 »
UK model is the 4DX which has a MPH speedo and fitted with a non restricted CDI/ecu. IMports are the 3tj`s 1, 2 ,3, 4, 5, depends on the year of manufacture, speedo is KLM and has restricted cdi/ecu. both bike looks exactly the same apart from the tail light. thats all i know am afraid, well its what i have read anyway in the forums anyway :grin: .
Re: UK FZR400RR
Post by Evilchicken0 »
All that and the UK bines have an oil cooler. I preferre the 3TJ tail light.
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Re: UK FZR400RR
Post by Hogdigerdy Dog »
i may stand corrected
but the 3tj1 and 4dx are the same beast, it's only the SPs that had the oil cooler
the 4DX from 1992 to 1995 (ie UK spec) are the same as, give or take, the 3TJ1 (which was 1989 onwards)
the models with the oil cooler were the SPs marked as 3tj 2 /6 /7 ( possibly the earlier 2tk sp had an oil cooler but i'm not sure on that one) see here
http://www.rampant-racing.com/fzr400models.html
and yes the inlaid 2 piece tail light looks the dog's, compared to the massive disco light on the 4dx
3tj rule
KIYOSHI
Re: UK FZR400RR
Post by KIYOSHI »
Uk bike had mph clocks, heat transducer (often mistaken for oil cooler) same as sp, unrestricted cdi, painted frame and swingarm ( not brushed effect ), larger rear light, different carb main jets, slightly different wiring loom, rounder mirrors, single nut on rear wheel spindle,,,,,, think that's about it,,,,,,
thunderace
Bike owned: R6, YZF600R
Re: UK FZR400RR
Post by thunderace »
UK bikes don't have amber running lights :peace:
Re: UK FZR400RR
Running lights are American.
Nice one with the lock nut on the rear spindle. When I went to a track day I had my tyres changed by the fitter there. God they made a meal of it and got all unptight over that lock nut, they were going to try and move it with pliers !!!
KIYOSHI
Re: UK FZR400RR
Post by KIYOSHI »
4dx also had a metal bracket below the number plate for a reflector and more foam under tank.
nick
Re: UK FZR400RR
Post by nick »
.......and, after much research, the UK frame my be different to the import
LONG story, but if you ever go down the hybrid route...............enough said :whistle:
