73A cant rev past 8k
Hi guys,I just bought a 88 73A gsxr400 for $500nzd.
It is in good tidy condition for the age of the bike,
It had been sitting in a garage for just over a year, as the guy had been in a accident,
it started but i cant get it to rev over 8 - 9K
I took the carbs off and took the bowls off and tops replaced all the o-rings,cleaned the jets etc etc,put back together(It runs good down low but still the same prob.
The guy I bought it off said he took it to a motorbike shop 1 and a half years ago and they had replaced the jet needles with gsxr 600 ones as the old ones were worn and they couldnt find any stock replacements
I noticed the E clip is at the very top notch of the needle and the jet sizes are 97.5 mains and 32.5 pilots,does that sound right?
Re: 73A cant rev past 8k
The GK76A should have the clips in the middle from factory if i remember correctly, it might be worth moving them down. Someone more experienced with the 73a might be able to help.
- Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Hey,bumrash wrote:Hi guys,I just bought a 88 73A gsxr400 for $500nzd.
32.5 is standard size for pilots,mains are about right(standard) if my memory is anything to go by!. Needle clip should be on position 3 (from the top) as a start point,try this and go from there.Make sure the carbs are balanced properly and you have no air leaks anywhere(inlet rubbers etc,,,). I have a little experience with the 73 but not as much as Chris (variable valves) and he would be the man to interigate! Hope this helps....
Andy
Thanks guys,i dropped the E clip and now it seems to rev out properly,(I dont know why they had the clip at the top off the needle)
I will balance the carbs today and get a voltage reg as it's reading 18.4v at the battery
