76A oil line/pipes wanted
dobbslc
Bike owned: 3TJRRSP TRX850 XV750 cafe
Post by dobbslc »
I've just seen an old post about the cam feed oil lines (the metal internal ones), someone said you can get braided ones. Is this true? as I've bent mine undoing the cam caps.
Variablevalves suck
Re: 76A oil line/pipes wanted
Post by Variablevalves suck »
Ive never seen braided on the inside, people fit them on the ends (outside). I will have one spare, will have a dig morra. To be sure you mean the ones that go from intake to exhaust cam and are held by the cam journal banjo bolts. And regards the valve seals you will have to buy OE as the 76A has stupid fine valves that are not used on anything else.
Chris.
dobbslc
Post by dobbslc »
Top man Chris,
I've worked out that you can't get pattern valve seals so will order some Suzuki ones. :x Crooks seemed the most friendly so will probably get my cash.
The pipes I need are the internal cam feeds as I bent them slightly undoing the cap bolts DOH!
Do you know if it's possible to measure the oil rings as I can't find any details about them.
Rob
Variablevalves suck
No measurements for oil rings. If you only bent the oil pipes slightly they can be straightened by hand as they are super soft so long as you havnt kinked them.
dobbslc
Post by dobbslc »
I've just been told that GSXR600 SRAD valve seals are the same as gk76a one's., He cross ref'ed them and the part numbers are the same, £12 for 10 pattern parts.
The seals didn't fit so I had to buy the oe ones :down: :down: :down:
