Restricted?
callies
Re: Restricted?
Hi Guys
Can someone please post some pics of how to wire up this 2.2K resistor.....
I have read about his allot but with not a single explanation (wiring diagram) on how to achieve this..
Callies
Callies
Re: Restricted?
callies wrote:Hi Guys
I have read about his allot but with not a single explanation (wiring diagram) on how to achieve this..![]()
Callies
its the orange and blue wire on most models, to ignition live 12v +
Peteo
- Bike owned: 93 NC30
Re: Restricted?
I only asked a question!!! sorry to cause a riot!!!
But a big thanks to ALL! your help guys.
Still a bit confused! So basically the boxes on ebay do jack s**t?!!!
Stick to the resistor mod then?
I will give it a good spanking the weekend and let you know what I get out of her! speed & RPM!
Again sorry to start an arguement!!!!
Pete
Pete
Re: Restricted?
If you read my summary of speculations about what they do on the previous page you'll get an idea.
If you already have one it's not going to cause harm.
I wouldn't pay that much for one though, you can get an Ignitech Programmabable CDI unit for that much that you won't have a speed restrictor on it and you can setup the igntion map to the bike.
Rick.. if there fetching that much you could sell yours and get an ignitech ecu.. I think that'd be a good idea.. into the lab for programming
Peteo
Re: Restricted?
I think i have decided to purchase one of the Ignitech Programmabable CDI units
cheers for your help!
Re: Restricted?
No worries.
The ignitech box's are great, ask around in the general disussion for peoples feedback on them.
You can get a copy of the HRC map for it (so in effect it is the same ECU as a HRC one.. you can also get standard maps or even build your own (if you have time and a dyno to test things :D)
Ultimate tool for fettling with the bike though... :)
Re: Restricted?
ref the ignitech..
I tested mine back to back with std and it was 2bhp down. So, it is not a magic bullet at all and does need to be fettled a lot to be significantly better than std.
I do find my ignitech box makes the bike respond better, rev more freely and overall feel much more lively. The dyno told the other story.
I think I had too much advance and too little compression dialled in and so I was fecking up for myself.
I've sorted that now..my bike feels lovely!!
- banoffee
Re: Restricted?
Am running the HRC map with 2 degrees less advance, redline set to 14,500 and the tacho output corrected. Very pleased with it, great bit of kit for the money.
Peteo
Re: Restricted?
Where did you get the HRC map from? and what do you mean by 'Tacho output corrected'?banoffee wrote:Am running the HRC map with 2 degrees less advance, redline set to 14,500 and the tacho output corrected. Very pleased with it, great bit of kit for the money.
Pete
- banoffee
Re: Restricted?
Rick Oliver supplied them. I settled for the HRC-2 one after trying them all. There is an option in the software to adjust the rev counter output as it's not 100% accurate as standard (mine overread considerably). So now, 14,500 redline in the software and it does stutter at 14,500 now instead of the 15,000ish it showed before.Peteo wrote:Where did you get the HRC map from? and what do you mean by 'Tacho output corrected'
