Quick Action throttle - recommendations please
vr46
- Bike owned: All sorts
Hi,
I've seen few NC29's with quick action throttle kits fitted, can anyone tell me which one will fit and where to buy one as I can only find HRC CBR600RR kits.
Cheers :)
VR
Cheers :)
VR
Skint Novice F400
vr46
Re: Quick Action throttle - recommendations please
Just been looking through the boards and found this thread:
http://www.400greybike.cc/newforum/view ... 983&p=7313
Skint Novice F400
tanuki
you will need an NSR250 throttle body and tube..however you will either need to run without a return cable or get one made up and the standard one will be to short.
stimpy
yep...nsrmc21=hrc nc29 throttle...you will need to shave the little bit that goes into the throttle tube down by 2mm to get it working properly...otherwise it catches
stimpy
stimpy
trickyd400
- Bike owned: NC23 x3, NC29, Beta & NC31
Does this work for the NC23 too?
stimpy
yep...i have 1 on my nc23
stimpy
stimpy
marty400
Sorry, Newbie question!
What does this "Quick Action" thing do?
Is it only really for the race track? (Ie. Does it compromise rideability in commuting traffic etc?)
Hope you can advise
Martin
Hope you can advise
Martin
stimpy
it will be fine on the road...basicly you can go to full throttle in under 1/4 of a turn
hope that helps
stimpy
hope that helps
stimpy
