led indicators on rvf400
ok im having some problems getting my indicators working on my rvf
i have 4 led indicators, 4 50w led resistors
now im not sure how to fit the resistors
front i have left hand side orange, orange/white green
right hand side blue, blue/white / green
rear green, orange and blue
im guessing blue/white and green/white i dont use
so to which wires do i connect the resistor?
thanks alex
thanks alex
Re: led indicators on rvf400
Correct, the white striped ones are for side-lights :-)
Cool . Do u know how to fit the resistors tho?Neosophist wrote:Correct, the white striped ones are for side-lights :-)
You mount them between the 2 wires that go to each indicator (bridge).code2006 wrote:Cool . Do u know how to fit the resistors tho?Neosophist wrote:Correct, the white striped ones are for side-lights :-)
Resistors are a very dodgy fix to LED indicator problems IMO but they should get the indicators flashing at a more decent rate. Much better to use an electronic flasher but some other mods might be needed (they were on my nc30).
Yer I saw your post but I don't know if the same applies to the nc35. Do u know were I can get an electronic flasher?Cammo wrote:You mount them between the 2 wires that go to each indicator (bridge).code2006 wrote:Cool . Do u know how to fit the resistors tho?Neosophist wrote:Correct, the white striped ones are for side-lights :-)
Most auto stores carry universal electronic flasher relays.
Cool maybe my local car spares place might have some. I guess this replaces the normal relay which is near the cdi or wot ever it's called the big box lolCammo wrote:Most auto stores carry universal electronic flasher relays.
