Will it fit?
Andy
Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Will it fit?
Post by Andy »
Hey,
Yeah i know i dont post very often but been busy...! I`ve popped the motor in the 73 so i`m looking for a replacement it`s just toooo damn expensive to rebuild to a good standard/tune etc. Question is will a variable valve bandit motor fit ok(i think it will)and just what is the difference between the two and are there any extra ancilliries required with the the bandit mangle?
Thank`s fella`s
Andy. :grin:
Benr
Bike owned: Suzuki GSXR400RRsp GK73
Re: Will it fit?
Post by Benr »
What about a bandit 600 lump?
Andy
Re: Will it fit?
Post by Andy »
Benr wrote:What about a bandit 600 lump?
Too big(width),tried it!
Andy :grin:
Variablevalves suck
Re: Will it fit?
Post by Variablevalves suck »
Hi Andy,
I know the standard bandit motor will fit the 73A but the VVC motor will not fit the standard bandit from without work due to the cam sensors and carb tps sensor making the motor wider so if the standard unit is tight you may get problems. Also the cdi for the VVC is a 12 pin unit as per SP GSXR so you may be better finding a standard bandit engine and then swopping the cams over.
Andy
Re: Will it fit?
Post by Andy »
Variablevalves suck wrote:Hi Andy,
Thank`s Chris,
I`ve got lucky and collected another bike for the right money so problem solved
Andy :grin:
