are RF carbs the same
dl
Bike owned: GK76A
Post by dl »
Hi everyone
Could any one tell me if the carbs from a suzuki rf 400 are the same as my GSXR 400 GK76A if not is there anyothers as I have 2 stuck mixture screws that will not come out and I want to replace the o-rings.
Dave
Jaicen
Bike owned: GK76SP & ER6F
Re: are RF carbs the same
Post by Jaicen »
dl wrote:Hi everyone
Dave
As far as i'm aware, the carbs are the same as on the RF600 and RF900, unless you have a GK76a SP, in which case the carbs are different.
dl
Bike owned: GK76A
Post by dl »
Thanks for the advice, this forum is ACE !!!!
Variablevalves suck
Post by Variablevalves suck »
If you got pilot screws stuck in place you put the carbs upside down on a bench, put Quality penitrating oil (not wd40) in and leave acouple of days, then using a GOOD fitting screwdriver you will get them out. Ive had plenty stick due to corrosion between the zinc washer and carb body and always got them out.
dl
Bike owned: GK76A
Post by dl »
Thanks For the advice, I have tried everything from heat to impact screwdrivers, in the end I have had them machined out by a engineering freind and have ordered two new screws, hopefully all thats left to do now is fit all the new orings and enjoy for the rest of the summer( if we get anymore sun!!!!) Thanks Again for the reply
Dave
