sticky rear caliper
anth
sticky rear caliper
Post by anth »
hi, i am new to the bike world av been buyin a nc30 and the rear caliper seams to be stickin on does any1 no any quick fixes to this of how i can fix it
any help would be great
thanks anth
Re: sticky rear caliper
Post by Neosophist »
is it always sticking on or sticking on after use?
there isn't a quick fix for brakes (and it wouldn't be wise anyway, bodged brakes = bad)
Strip / Clean rear-caliper should sort it.
If it's sticking on after use make sure the level of fluid in the rear brake isn't over-filled.
niffter
Bike owned: NC30, Yamaha TY 175
Post by niffter »
I had a similar problem and it turned out to be corrosion underneath the rear caliper dust seals.
fatpete
Bike owned: NC35 (RIP), CBR900RR, NC 30
Post by fatpete »
I had real problems with mine sticking on, I took the caliper off and copper greased the slides, cleaned the small bleed hole in the master cylinder and put an elastic band on the pedal to ensure it returns fully. Then bled the system it is all working fine, my guess will be the slides needing greasing.
