RE:NC29RRN - what spanner buy to adjust the Std Rear Shock?
Hiya All,
hope you can help.
What make/model C- Spanner should I buy, that will adjust the Std rear shock?
(Ie to loosen the locknut, and also the preload adjusting locknut?)
I'm trying to adjust the standard rear shock on my NC29 - but the C-Spanner in the toolkit won't fit! I've given it a good go, to loosen the locknut, and also the preload adjusting locknut. I have also tried a cheapo "adjustable" C-spanner. All no good, the spanner is slipping off lots, and I don't fancy damaging fairings or framework etc!
The spanner in the NC20 toolkit looks exactly the same as the spanner for my old CBR600 - where the rear shock had those 6 settings. The NC29RRN is totally different, with the threaded locknut for finer tightening adjustments.
Hope you can advise
Martin
hope you can help.
Hope you can advise
Martin
- Davez29
- Bike owned: NC29 forever
Re: RE:NC29RRN - what spanner buy to adjust the Std Rear Sho
I use a hammer and a long bar from a socket set, tap.. tap..
- superlite
- Bike owned: TLS, LB80 x 2
Durka Durka wrote:I use a hammer and a long bar from a socket set, tap.. tap..
I've found it's nearly impossibly to adjust the preload while the shock is under load (especially if it's weathered a bit). An Abba stand/axle stands/jack makes it a breeze.
'Take it to the Back'
aaaahhh!superlite wrote:Durka Durka wrote: I've found it's nearly impossibly to adjust the preload while the shock is under load (especially if it's weathered a bit). An Abba stand/axle stands/jack makes it a breeze.
good point!
- Bike owned: NC29, CBR6F2
I'm happy to draw up a template from the one I have made at A4 size and email that to anyone who might want to make one themselves.
Use 4-5mm mild steel plate, a jigsaw and a file and it should take about 30 minutes.
Matt
Matt
matt69 wrote:I'm happy to draw up a template from the one I have made at A4 size and email that to anyone who might want to make one themselves.
Matt
Hiya matt, that would be awesome if you could! I.m. If you cAn. Also cab u attach to this thread for any others?
[/quote]
Hiya matt, that would be awesome if you could! I.m. If you cAn. Also cab u attach to this thread for any others?[/quote]
et voila
Print out at A4 size and use 5mm mild steel and it should work nicely. I have used alloy plate, but the tip is too soft and it rounds off quickly. I've got the steel in the shed to have a go once my crash damaged hand isn't......
Matt
et voila
Matt
Hiya matt, that would be awesome if you could! I.m. If you cAn. Also cab u attach to this thread for any others?[/quote]matt69 wrote:
et voila
Matt[/quote]
THanks Matt! 8)
