fzr400(3tj) r6 shock conversion adapters who would like one?
Re: fzr400(3tj) r6 shock conversion adapters who would like
My old computer read Shite InsideStrikmabill wrote:Fisher price would be hilarious. Let us know if someone falls for it.
				RoadDogma
- Bike owned: FZR400RR (3TJ)
Cheer again guys! Oollit, I know that you have given that to me before, but I was also told 350mm, so thanks for confirming.
				davidm
HI there, I've just put an 08 rear shock into an 89 FZR 600 (same frame as the 400s). It is a bit shorter, not to mention the thinner bolt needed at the top, with appropriate bushes.  So this invention to lenghten the shock with an add-on at the bottom is just what I need. If you're still doing them, how much to ship one to Sydney?? and thanks for the invention!!
David M
						David M
- Kayla850
- Bike owned: Sunn Tzar S2
Here you go-davidm wrote:HI there, I've just put an 08 rear shock into an 89 FZR 600 (same frame as the 400s). It is a bit shorter, not to mention the thinner bolt needed at the top, with appropriate bushes. So this invention to lenghten the shock with an add-on at the bottom is just what I need. If you're still doing them, how much to ship one to Sydney?? and thanks for the invention!!
David M
http://www.projection-components.co.uk/ ... s-17-p.asp
Shipping to Australia is £3.99
www.projection-racing.com
www.pjcfasteners.com
Are we sure ????
If it's a 3HE then it should be similar to the 1WG 400 ... so you should be down about 25mm at the back ??? Normally that's taken up on the dogbones.
				davidm
Yes please! I've just dropped an 08 R6 shock into an 89 FZR600 n its dropped the rear a cm or two. Lovely shock tho.  I'll need you to mail it to Sydney. Racing Mar 23-5 in the BarrySheene Festival here see www.barrysheene.com.au. He was another great Brit export. Cheers David M & davidm@csrsydney.com
