Slides holes.
Slides holes.
Rick Oliver wrote somewhere that incresing slies holes from 2 to 2.5mm affect the responsiveness of the slide (larger or more holes means a faster responding throttle).
That what they have on NC30
But when I tried to make same on NC29 I saw following
There is no hole, just this 2 small "deepening". So, is it possible ( or reasonale ) to do with NC29 slides?
- Bike owned: NC29 and NC35
Re: Slides holes.
I have the RRR model which had those holes in already. When i bought a Dynojet kit it came with a drill to enlarge the holes
Re: Slides holes.
Are this hole is "penetrating" ?LUCAS wrote:I have the RRR model which had those holes in already. When i bought a Dynojet kit it came with a drill to enlarge the holes
- Davez29
- Bike owned: NC29 forever
Re: Slides holes.
Hi Parus, to confuse things my R model only has one of those holes all the way through.
Re: Slides holes.
I have L model.Durka Durka wrote:Hi Parus, to confuse things my R model only has one of those holes all the way through.
Re: Slides holes.
Ok a couple of pictures to help maybe:
Poking the needle through to show the hole (both are the same) is all the way through:
Both holes were all the way through when i got the bike. Then installed the Dynojet kit and they were then both enlarged with the supplied drill bit
- Davez29
Re: Slides holes.
So can anyone enlighten me to why Parus slides has no holes, mine has one and Lucas has two, which is OEM standard
Re: Slides holes.
I have just fitted a Moriwaki system and it really messed up the jetting. I emailed Graeme France for advice (which he came back with very quickly as always) and he is very clear that the R model has 1 hole. I need to check the model of carbs as they dont appear to be R model carbs!Durka Durka wrote:So can anyone enlighten me to why Parus slides has no holes, mine has one and Lucas has two, which is OEM standard
So R model do have 1 hole is appears
Re: Slides holes.
Ok having been told that it was an R model by the guy when buying it (I didn't know what to look for at the time from one model to the next), now having looked through the manual, checked the frame number and other things such as forks, shock, its actually an N model
Its nice to know exactly which model i have and proves you cant take peoples words as being 100% exact. Sorry for the confusion it may have lead to on here
I will go away and sulk for my inferior bike lol
Re: Slides holes.
My question what is better two or one holes ? I suggest two holes is better...
