nc 30 clutch repair will pay co durham
hi i need a member to come and help me fix clutch on nc 30 i will pay for any work done ......ian
Re: nc 30 clutch repair will pay co durham
where bouts are you and whats rong ?
replaced clutch and there is about a 5 mm gap between circlip and outer thrust casting i will be up for a while just let it ring once an i will call you back ..ian
dont have my mobile on me m8, mmm you sure you put back together in rite order ? also all plates etc, rite amount of springs and there not screwed ?
i have put the clutch back together about three times now and still no cigar springs are bout 5.5 mmm as specified its like there is a plate missing ....................but there isnt
thats weird something would have to look at, i had a weird problem with my clutch basket before i had to replace it it was like having a automactic bike lol
well write my mob number down and if you can b arsed give me a ring
sherburn village
how many plates have you fitted?
Did you measure the stack height? If not, what is it?
did you replace steels? How many springs?
- Bike owned: Vfr 400 nc30
I know what you mean.......after putting the 10 new friction plates in and putting it back together i had the 5mm gap when you pull the clutch in theres nothing there...Its actually like theres a clutch plate missing but theres not. Did you align the outer part with the teeth and tighten to 85nm....
