foyeye /thundercat starter solinoid /relay
sparkles
- Bike owned: 1990 fzr6 3he with a 4jh engin
Re: foyeye /thundercat starter solinoid /relay
Yes i did and thanks
I printed it on glossy paper but its unreadable so will try normal paper next time i get chance to print it off round my dads.
Found out the other day that if you run a wire fromthe blue and white wire that goes to the solinoid to earth then that tests the starter and solinoid
I now have a wire that runs from blue and white wire to negitive on battery and has a fuse holder that is between riders seat and fairing under seat on left hand side so all i have to do it hold fuse in place long enough and it starts which saves taking seat off each time and putting something cross tewrminals on solinoid
Still not worked out whats stopping it start on the start button but getting there
sparkles
Turned out to be a loose wire by the main relay had come loose after some corrsion had main it come loose.
It now starts on the button
hunter
Good to see your sorted.
