Shims
- Deviant400
Shims
can anyone reccomend a place to get shims , (nc30) pref mail order as there is no where around here that i can get them from , im in the middle of doin mine , iv done cyclinders 1and 3 and 2 shims are out of tolerance so far , ive managed to juggle them around so only needing 2 on these cylinders so far, ill be doin the front cylinders on friday as i finish work early but want to replace them asap
viewtopic.php?f=62&t=27307
Re: Shims
Where are you?
http://www.wemoto.com/bikes/Honda/VFR_4 ... C30/90-91/" onclick="window.open(this.href);return false;
We moto sell them in most sizes
- Deviant400
Re: Shims
haha kool i was just lookin at those , think they will be just fine , im near devvizes in wilts , thanks neo
Re: Shims
Get in touch with a forum member called rick oliver. He'll do an exchange of yours for his plus £1 per shim i think and if he can't he'll get you new ones.
Re: Shims
You can buy them mail order from david silver etc but they're not cheap, ~3quid each last time ISTR.viper_biker wrote:Get in touch with a forum member called rick oliver. He'll do an exchange of yours for his plus £1 per shim i think and if he can't he'll get you new ones.
£1 a shim is a decent deal, after all unless you have lots of bikes or are very lucky what are you going to do with the old ones?
Druid
- spooky
- Bike owned: nc24
Re: Shims
Ahh sure you could just drop them down the holes and they will fall into the sump for safe keeping till you need to do them again.....NOT....
- Deviant400
Re: Shims
well if mr oliver does swapsys then id like to replace all of them and get them all bang on the middle of the tolerences as some are just out and some are just in range , where i would of just replaced the ones that are out it seems more viable to do the whole shabang instead at £1 for each one exchanged , my spare ones i was gunna use as fillings for my teeth
not funny as i nearly did throw one down there , using a blob of grease on the end of a driver is the crappest idea in the whole history of crap ideas, went an got me one of those magnet thingy ma bobs on a telescopic rod so should be just the job,Ahh sure you could just drop them down the holes and they will fall into the sump for safe keeping till you need to do them again.....NOT....
Re: Shims
You might not need to replace all 16 as ones in other parts of the motor will go somewhere else. That's how I've always done mine. 1 bike I did had 14 shims needing replaced but I only needed to order 8 in total after swapping some around.
- Deviant400
Re: Shims
yeah thats my plan of attack , juggle them about a bit see whats required doubt ill need to replace all of um
- Deviant400
Re: Shims
just to check ...its the measured gap minus the midway point of tolerance then add the exsisting shim size = the required shim size
so it would be summit like this (exhaust valve)
measured gap= 0.20
mid point between 0.21-0.27 = say 0.24
current shim 2.35
so 0.20 - 0.24 + 2.35 = required shim 2.31
does this sound like the right formula ???
measured gap= 0.20
current shim 2.35
