Fork Seals
morris147
Fork Seals
Post by morris147 »
right im looking for a copy of a haynes manual so i can do my fork seals but cant find one.has anyone got a haynes manual or a guide to change the fork seals on a gk76a?
cheers oh and here she is:
morris147
Re: Fork Seals
Post by morris147 »
anyone?
i really need help!!!
Variablevalves suck
Re: Fork Seals
Post by Variablevalves suck »
Hi Morris,
They are pritty simple to do.
You want to crack off the big top cap with the forks still in the yokes and then after dropping the legs out you take these out under a little pressure ( as the spring can fire out), if they only got pre load you can then take the spings straight/spacers out and then undo the allen head thats up inside at the bottom of the forks, remove the dust seal and circlip and the forks will pull apart. If its got comp and rebound, after undoing the top cap's you have to undo the damper rod (its locked under the top cap with a nut) and then follow the other steps.
morris147
Re: Fork Seals
Post by morris147 »
still stuck, i have no idea how muc oil to put in or how to ajust my forks to how they were.
could really do with a haynes manual if anybodies got one.
Variablevalves suck
Re: Fork Seals
No Haynes and only got gk73a info after my PC lost all the gk76a stuff, D'oh!
Best i can do is the site below where you can get an exploded veiw of a 91 rgv or gxsr750 forks that my help.
http://alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false;
vivo
Re: Fork Seals
Post by vivo »
Are you still looking for info on the fork seals? I have a giude on how to do them step by step. PM me with your email address if you want it.
stripes1976
Bike owned: 6 gk76a's, nc29
Re: Fork Seals
Post by stripes1976 »
vivo wrote:Are you still looking for info on the fork seals? I have a giude on how to do them step by step. PM me with your email address if you want it.
ah my fork seal guide still exists! gimme a call trev lost all the numbers in my phone :whistle:
