NC23 engine (again lol)
- Bike owned: VFR400R NC24, GPZ600R
Hey again guys, I be back!!!
I find that its difficult to get the cbr to engage into gear... when i built the engine i could turn the selector drum and it would change gear without difficulty...!
I've also noticed that the gear change shaft is very hard to turn..? could this be whats causing the problem?
would replacing the oil seal fix this problem or am i doomed to keep trying to find the cause of the problem for eternity
Cheers,
Adam.
Cheers,
Adam.
- w00dzy
Re: NC23 engine (again lol)
I take it you dont need an engine still?
Might need to adjust the linkage.. or you could put the nc23 aero shifter on it..
I'm gonna fit the new wiring loom and try get the existing engine started... If it still ain't running propperly I'll get that engine from you, should let you know in the next day or so,
cheers,
Adam.
cheers,
Adam.
I would check the shift assembly in the clutch side make sure everything is okay. Could also be a bent or burred rod. The seal wouldn't do it unless its the wrong one.
- chrisja2
- Bike owned: nc29 trackbike
Is it you Woodzy that has this on your bike, just that i saw someone had done it, but fecked if i can remember who! If it is, you got a pic?w00dzy wrote:I take it you dont need an engine still?
Chris.
- w00dzy
It is me indeed, got the idea from Drew.. works a treat.. dont have any pictures but will get one today..
ahh woodzy check ure pm's bout that engine mate
Got my electrics working btw, got a new loom and fitted it... voila
Adam.
Adam.
