renthal grips and bar ends
cbrjack
Bike owned: honda nc29
Post by cbrjack »
hi first real post here, i need some help. my bike (nc29) came with renthal grips but they werent put on properly. Has anyone got any advice on how to put them on properly so my new probolt bar ends will fit?
PARUS
Re: renthal grips and bar ends
Post by PARUS »
With water and soap you can put grips properly. Bar end fit easily.
garyboy_palaboy
Post by garyboy_palaboy »
its much easier to fit a rubber handgrips if you have a compressor. just put the nozzle of the hose of the compressor, apply some compressed air and slide the rubber grips.
Cammo
Post by Cammo »
I've always used hairspray.
Renthals also have 2 places that you can lockwire them on, I do this on my trackbike.
cbrjack
Post by cbrjack »
thanks guys tried today but i think the little threaded plastic inserts in the end of the handle have slid up the inside of the handle and turn when i try to tighten the bolts. is the a good way to remove the inserts?
justmartyn
Bike owned: Only 2 left.....
Post by justmartyn »
Get the bolt from the bar end and try and get a few turns on it, then rip the bastard out with a pair of pliers. then you can stick any aftermarket bar end you like up there. Plus you save about 3 metric tonnes of weight!
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Peel back the grips as much as you can and peer up the handlebar looking for a clip that holds the inner bar end weight inside and it should come out quite easy if it is still in there, it could be broken inside if the bolt wont tighten up.
cbrjack
Post by cbrjack »
ah that sounds like the problem, should about 7-8 mm of the grip sit on the bar end weight then thats how everything seems to line up at the moment
