XJR400 Rear Brake Caliper
Mike Shelby
Reactions:
Bike owned: 3TJx3 YZF750R XJR R1/6 CBR60RR
Post by Mike Shelby » Tue Feb 04, 2014 3:55 pm
Was trying to change the fluid and bleed the brakes on my XJR - front went fine then tackled the rear . . . thought one of the bleed nipples was un-doing and then snap!!! Bust right off flush with the housing :cry: .
I can still use the bike as the brake works ok - but does anyone know if the same caliper is used on another Yammy? I've checked on ebay but can't see one that looks the same. I do know when I had my UK FZR400RR 4DX it had the exact same caliper - but that is different to my 3TJ's strangely enough??!!
The MOT is due in May so not sure if it would pass with a busted nipple - but I'd sooner get it done anyway if anyone has any ideas please?
I thought about drilling it out but that will probably knacker the thread in the caliper. :(
Reactions:
Re: XJR400 Rear Brake Caliper
Post by Evilchicken0 » Tue Feb 04, 2014 5:57 pm
You have it spark eroded - it should take out the nipple while leaving the caliper intact, it's a specialist thing though so can't be done while you wait.
Drilling isn't a good idea if you go to deep you ruin the seat. Maybe an easy out would do the trick ?
rockTJ
Reactions:
Bike owned: GSX650F FZR250x2 RSV RG80
Post by rockTJ » Wed Feb 05, 2014 12:05 am
You can get a brake hose bolt which has a bleed nipple in it if you cant find anything in time for the MOT.
http://www.ebay.co.uk/itm/360838416255
Chris
mattiec321
Reactions:
Bike owned: GSXR1000K7 Monster HondaPX50
Post by mattiec321 » Mon Feb 10, 2014 12:49 pm
Rear caliper: the same as FZS600 (model year until 2004. two pistons caliper, 95mm hole to hole distance)
Maybe this could help, its the same as a Fazer apparently according to the common parts post
Return to “Workshop”
