Inline fuel filter on xjr400 93
CottonBudBear
Reactions:
Post by CottonBudBear » Sun Oct 26, 2014 7:30 pm
Struggling to find any info on this, but I'm fairly sure my bike has no fuel filter. Does anybody have any experience with these aftermarket inline fuel filters.. Will it mess around with pressure in the fuel lines/carbs?
Also if anyone has any workshop manuals on the xjr400 it would be appreciated.
Reactions:
Re: Inline fuel filter on xjr400 93
Post by Evilchicken0 » Sun Oct 26, 2014 8:16 pm
Do you have gravity feed carbs or fuel pump ? You can hear a pump ticking when you turn the ignition on.
If not the your fuel filter will probably be on top of the fuel tap - take the tank off and roll it on the side then unbolt the tap and clean the gauze filter.
I think the engine is like an XJ unit, have a look at the XJ600 manual
willandrip
Reactions:
Post by willandrip » Sun Oct 26, 2014 11:11 pm
Aye; the tanks on them are conventional without a fuel pump, Boris.
An inline fuel filter will not effect gravity fed carburation until it becomes clogged and restricted.
Kayla had one of these; and jolly nice it was too.
CottonBudBear
Reactions:
Post by CottonBudBear » Mon Oct 27, 2014 9:28 pm
Thanks for the replies, fuel filter has been ordered!
Reactions:
Post by Evilchicken0 » Tue Oct 28, 2014 9:16 am
See, I don't think it needs it and if it isn't standard I'd be loath to fit one
CottonBudBear
Reactions:
Post by CottonBudBear » Thu Nov 06, 2014 8:43 pm
1993 she needs a fuel filter,especially after cleaning the carbs
xjrnino
Reactions:
Bike owned: Yamah XJR 400
Post by xjrnino » Tue Mar 10, 2015 4:24 pm
There is a filter on the fuel tap inside the tank, take the whole tap out to clean it.
Return to “General”
