xivlia's thread of nc30 problems and questions
- Reactions:
- Bike owned: NC30+VFR750
Re: fitting a fuel gauge? to an nc30
HI
"ON" is main tank
"RES" is reserve tank
"OFF" is off
regards
Neil B
"ON" is main tank
"OFF" is off
regards
Neil B
- Hadies
- Reactions:
When you run out of petrol switch to reserve and head to a petrol station. When you start to feel the bike run out of juice and you're on the move, it's two clicks of the fuel tap to switch to reserve.
Try pushing down on the front of the fuel cap before turning the key. (The front as in the point closest to the yoke)
- xivlia
- Reactions:
- Bike owned: Ducati 749 D
. okay, i tried pushing down on the cap still no help :\ looks like the guy hasnt used the bike since 09 as the road tax disc says 09. and he probably hasnt changed fuel since then...
- Hadies
- Reactions:
It's possible that you may have the wrong key for the fuel cap. It would explain why your key doesn't fit properly.
- xivlia
- Reactions:
isnt the fuel cap key the same as ignition key? :O. i got 2 sets of keys with the bike...one is ignition.. which is the smaller key and one set of longer keys which i do not know what its used for...it doesnt even go in properly to the fuel cap so i dont know :\
- Reactions:
- Bike owned: NC29
dont use wd40. it will only make it worse
- xivlia
- Reactions:
well looks like it worked now. must of been the wd40
- iDemonix
- Reactions:
- Bike owned: '92 NC30
Don't you mean left hand side?hardnutdvd wrote:there is a tap on the right hand side of the bike, where the gap in your seat fairing is. there three positions, On, Off and Reserve.
the tap itself should have writing on it to tell you what position its at.
Also, as everyone has said, you'll soon learn when it's about to run out of petrol (stuttering, loss of power) and then you can flick to RES and go petrol hunting. Also, fill the tank the brim, set the trip counter to 0 and ride around. When you run out of petrol and have to flick to RES, make a mental note of how far you've done - that way you'll know in future when to start thinking about petrol.
From brimmed to the top mine normally needs to be flicked to RES about 170-180KM depending on how hard I've been riding.
- Reactions:
Re: can anyone help with restrictor kit installation? NC30
Cheers Dave,Man_Named_Dave wrote:He probably did, but then the previous owner of my bike did all kind of horrible things to it...xivlia wrote:the person i bought from said he used them on his vfr 400 nc30... :\
Look up 'porndoguk' on here- he is fabricating correct washers now.
follow the link bellow in my signature
- Reactions:
Have you ever ridden a motorbike before?
When the tank is full it holds 15 litres.
Switch to on it will use upto 13 litres of fuel.. when its running out the bike will start coughing and spluttering.
Switch it to RES and this will give you an extra 2 litres.. this will allow you to do around 30 miles if ridden sensibly and get to a garage :)
