Page 35 of 37
Posted: Fri Aug 12, 2011 1:56 pm
by jim157
HRC/Alan Partridge approved:-
Posted: Fri Aug 12, 2011 2:27 pm
They my old carbs then? Cool!
Posted: Fri Aug 12, 2011 4:10 pm
by reverse cylinder jim
CMSMJ1 wrote:They my old carbs then? Cool!
Yeah i lent him them to see if it was Tony's carbs at fault or something else.
Posted: Fri Aug 12, 2011 10:53 pm
by royster81
Posted: Fri Aug 12, 2011 11:02 pm
by Drunkn Munky
royster81 wrote:tony were you looking this ?
http://page2.auctions.yahoo.co.jp/jp/auction/b123612074
oooo hubba bubba :drool: I do already have one in the loft although if it stays at that price i may have to have it, I like the RT scheme and no doubt id put it to use one day.
Im really after the nose cone complete with mids that they do if you happen to come across one.
Posted: Fri Aug 19, 2011 9:04 am
by Will
demanding more updates boss, i love this threaddddd
Posted: Wed Aug 24, 2011 11:49 am
by Drunkn Munky
Not much to update except she's back in for surgery
Wheels are off and sold to be replaced with a standard set until i can find a set of magteks. The RVF carbs i borrowed worked well at first but then developed slight tick over issues which leads me to thinking im dragging crap through from the tank as i seem to be plagued with pilot circuit problems with every set of carbs i have.
Chris sent me a prototype kevlar sleeve to try
Im amazed he knocked this up in his shed, well done mate
Made a itouch mount for times when i want a speedo, hopefully there make a decent datalogger for it one day
Posted: Thu Aug 25, 2011 2:01 pm
by Drunkn Munky
The durbahn battery has finally made its way on to the bike, eventually it will be mounted up front but that needs a new loom and im fed up with looking at it sitting in the garage so its going here for the moment.
I think the cable sizing was a bit ambitious but i can change that later along with the anderson plugs.
Posted: Thu Aug 25, 2011 4:14 pm
by micpec
Tony, interested in the outcome of the prototype Kevlar sleeve can that Chris sent you. Are these for fitment on TSR pipes? ;)
Posted: Thu Aug 25, 2011 4:58 pm
by Drunkn Munky
Yes mate i offered them up today and there the exact same diameter. I'll order some new packing, trim it to size and fit it. Its very very light so it'll be a test to see if it blows to bits!
Bike is finally running very well, ive ended up with marks old RVF carbs which are setup as follows
Short stacks
HRC springs
130 mains
Standard pilots
Air screws and floats standard settings
Standard 0.5 washer (i think)
No airbox lid
Thin foam filter
HRC air tray
It needs a tiny amount of throttle to start weather on choke from cold or from warm with no choke, im not gunna worry about that as it idles nice @1500rpm and responds quick.
